EL006R-05 01/31/2006 Charging System - 'Charge' Warning Lamp ON
CBR_GUY_IA
ELECTRICAL
EL006-05
REVISED
April 18, 2005
Title:
CHARGE WARNING LIGHT "ON"
Models:
'03 - '05 4Runner (V6)
TSB REVISION NOTICE:^ January 31, 2006: T1 and T2 codes have been updated in Warranty Information. Previous versions of this TSB should be discarded.
Introduction
A limited number of customers that drive in areas where road salt is used during the winter may notice an illuminated charge warning light. Vehicles driven in these conditions may be affected by salt water residue getting inside the alternator. Performing the following repair will correct a "no charging" condition that may result.
Applicable Vehicles^ 2003 - 2005 model year 4Runner vehicles equipped with the 1GR-FE V6 engine produced BEFORE the Production Change Effective VINs shown below.
Production Change Information
Applicable Warranty:
This repair is covered under the Toyota Powertrain Warranty. This warranty is in effect for 60 months or 60,000 miles, whichever occurs first, from the vehicle's in-service date.
* Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Parts Information
Repair Procedure
1. Remove and replace the alternator with the updated part.
2. Remove and replace the oil baffle plate (found on the driver's side bolted to the engine intake brace) with the updated part.
3. Apply the foam strip to the engine cover as shown.
NOTE: Throughly clean the engine cover mounting surface before application
