New to the forum. Hope to be a long time member. If I don't sell it.
I'll try to be as specific as possible.
I bought my 1998 T4R LTD around 5 years ago, And have had a few elec. issues, but maybe more about those later.
The problem that made me google, and find/join the forum is this...
I went to the store, got out, hit the alarm, and heard the beep you hear when the door isn't shut all the way. I opened/closed all the doors multiple times without any luck. Same beeping.
So I just shut the door, and noticed the "door ajar" light was on (not bright, but dim)
Anyway I put the dome light in the "open door" position to see if it was an issue with the buttons, and it turns on/off with the door. After that, the "door ajar" light went off. So I tried to set me alarm again, and when I looked inside to make sure the "door ajar' light was off ..it was, but now the damn (small green) indicator that tells you what gear your in [PRNDH21] was on (also dim). The only way I could get all the indicator lights to stay off was to not set the alarm.
2 things that may be of consequence...The truck does have a branded title so that may be my answer right there, and it has rained a heck of a lot this week making me think water is making some kind of weak connection.
OK I rattled on enough I think. Any questions, experiences, suggestions would be appreciated.
Thank you for reading...... Steve
