Thanks, my 2004 sr5 is not sending any voltage to the ecu. When you try to start the engine, the check engine light does not come on, so there is either the ECU damaged or a cable that is not working. A friend with a scanner try to find the problem, but there is no signal coming from the ECU. I need the electrical diagram related to the ECU or the check engine light.
