Electrical Gremlin... windows, locks, doors
Scat Adams
Lately I've been having issues with my windows, door locks and power mirrors not working. Here are the symptoms;
What works;
Driver window
Sunroof
Key fob unlock/lock
(Also all of the doors unlock when I open the door)
What does NOT work;
All passenger windows (they were working intermittently before but now none of them work)
Door locks from any panel (Sometimes I can unlock the doors but can never lock them)
Side view mirror controls
Has anyone had any problems like this? Seems like it could be a faulty ecu. Plan on removing the door this weekend to inspect everything.
Any help would be appreciated before Im forced to pay the $100 diagnosis fee at Toyota!
Thank you!
was the car in a wreck before?
is the connector plugged in all the way at the door jamb?
pull the door to see if the plug is seated correctly on the window switch.
its only 2 screws and one pop rivet
As @gshadow235 said
-check fuses with flashlight
-unplug battery for 15 min
-check that rear wiper blade is seated in its groove
-window lock button
Sounds like a faulty connection somewhere
PO said it was in a small fender bender, I will check out all the connections and pull the door panel tomorrow. Ive already checked the fuses and disconnected the battery to reset everything. I will get back to you guys if Im still having problems.
Thanks for the quick responses
