Three mechanics, two sensors (TPS, knock sensor), one wiring loom (knock sensor), and those two sensors were replaced twice. Lots of $$$$$$ so far. Please help!
Problems:
- check engine light on
- code 52 (knock)
- code 41 (TPS)
Trans: confused! Won't shift down when peddle push to the floor, on the freeway the trans won't shift into overdrive (at 4-5k on freeway). Rapid shifts on cruse control, Shifted into first on freeway, thank you rev limiter. Can shift it manually just fine, except OD (which is electronic button on shifter)
Engine: sluggish, bogged down, lots of fuel consumption!!, rough idle (dies at stops), when cold and throttle at 5% there is a dead spot that kills the engine, no pinging, surges at idle.
Brakes: say I am coming off the freeway on the offramp, as your coming up to the intersection you start with slight pressure then slowly push the brakes on when you get down to 30-35 mph the 4r pushes back pushed up the peddle then slamming on the brakes with no input from me. Locking up only the front wheels.
Stock alarm and keyless entry: The alarm will go off with no provocation. I was even driving down the road and the doors locked and the alarm went off.
I don't know if they are all connected in some way, but please someone help! The Japanese specialist had 7 4runners in there for the knock sensor, wow Toyota needs to do something about that!
1990 4runner 4x4 3V V6
2003 CBR 954RR
Steal braided brake lines
PClll
Quick shifter
Ignition module
138 hp 85 ft lbs torque
530 double o-ring (never go to 520!)
Problems:
- code 52 (knock)
- code 41 (TPS)
2003 CBR 954RR
PClll
Quick shifter
Ignition module
