Electrical problems, om617 swap
Beardedclam
Hey all,
I've got some electrical problems that I cannot seem to figure out. Truck has been in working order, I was doing some rerouting of wires to make the swap more 'clean', and now the key does nothing. The things that work right now are:
Door ajar lights, headlights, DRL's, blinkers from the hazard button, tail lights, reverse lights, dome lights, door ajar w/key in ignition buzzer, and headlights buzzer, horn. All the fuses in the drive kick panel and in the engine bay are good
Put the key in, buzzer sounds, turn to acc, nothing, turn to on, nothing still.
Had a blown ignition fuse after some rewiring. In my haste, I had the battery connected and a live wire touched the block, sparked, i'm guessing that's what blew the fuse. What else is connected to that fuse? and where might those relays and whatnot be located? I think it's either a ground somewhere, or a relay?
DJNutshell
