Electrical Wiring Problem
hulk311
Ok, so my 12 volt outlet stopped working in my 4Runner. I put in a new 15amp fuse but that didn't fix it. I bought a new 12 volt outlet and took the old one out, also didn't work.
So I bought another 12v outlet, this one with long power and ground wires. I installed the ground wire to a bolt in the truck. I then hooked up the power cable to an old power cable.
Let me explain, I installed aftermarket fog lights a while back and they have now stopped working. I don't plan on fixing them (long story) so I taped the power wire from the new 12v outlet to the existing power cable that was used to power the fog lights. I should mention that the power cable from the 12v outlet has an inline 15 amp fuse (just like the stock one did).
Now, here is my issue:
1) My Iphone says its connected, (the icon changes) but it does not charge.
2) When I plug in the GPS, the green light goes on the charger that plugs into the 12 v outlet however the GPS does not charge.
3) When I plug in my seat cushion that has heat in it the light again goes on the charger that plugs into the 12v outlet however the seat cushion does not work.
All three devices work just fine in my wife's car.
Does anyone know what is going on??
The only thing I can think of is that I have two fuses and somehow they are blocking the power? I know the new 12v outlet power cable is 15 amps, but I am unsure how many amps the fog lights fuse is. I have about four power wires hooked up to the battery so it would be kind of hard to see which one is for the foglights.
If the fog light fuse is bigger than 15amps, would that cause the 12v outlet not to work correctly? Should I just take the 15a fuse from the 12v outlet? What would happen if the 12v outlet would run on a power cable with say a 30amp fuse?
Sorry for this long post but not having a 12v outlet is killing me and I've tried so many different fixes! :dammit:
Update, so basically all three of my devices, when plugged in, show that they are plugged in but they do not charge. Any ideas why?
tuṣṭāva
