so swapped in an elocker 3 weeks ago and have not driven much above 65. The other day I was on the freeway ( rare for me) and had it up to 75 and a vibration came on that I could feel in the steering wheel. So I went and had my KO'2s rebalanced. ( Costco) No difference. So then I thought maybe its ITRE's or upper ball joints ( only thing I did not do last year)then went to a shop I trust for alignments etc and had them throw it in the air, no suspension issues. But my sway bar bushings are pretty squished/cracking
Could it be that I need to rotate my drive shaft where it mounts to the pinion ? Ive read about that. And if so, I know its 4 bolts, does that mean I have to try it 3 more different times or do those 4 only line up 2 ways.?
where I live and work it is difficult to get up to speeds above 65, ( twisty 2 lane mountain roads) so I would not really know until I could get to a freeway.
no leaks or no movement at pinon seal or bearing, I have no idea what the miles or year the elocker came out of. It is correctly geared. we used my axles so its not like I picked up a entire rearend that had a bent axle
