Emergency Brake light coming on while driving.
Krazynative
Member
This seems to be getting worse. When I make left turns with speed, the light comes on. Only when making left turns.
It started when really turning hard with speed, now it is almost every time I'm making a left. There isn't any buzzing like when you drive with the brake engaged, just the light coming on itself.
Has this happend to anyone before. Where is the switch that turns on the light located? I looked under the dash where the foot peddal is, but didn't see a switch like in my 2nd gen.
I might have found the problem. After searching some more(let the flaming begin now), i saw a thread mentioning the brake fluid level.
I just replaced my front pads not too long ago and added speed bleeders. I did a little extra pumping on them to make sure no air was in the lines. The fluid was low, but not below the too low line. I'm sure the brakes have worn a little and the fluid is lower. Need to get some fluid in there and see if this is the problem.
Still not sure why it only does it while turning left.
"(let the flaming begin now)"
:gun4::gun4::gun4:
There used to be a flamethrower but I cant find it
lindwlson982
