Engine and tranny out
Ricktuk
Pulled engine and tranny out of Squish (rolled 98) and for sale on craigslist. I have salvaged Power steering pump, compressor, power window controls to put on ebay,
Any other parts anyone would recommend salvaging? or that anyone wants.
Why not list the truck for parts in the forum. I am sure there are so many who are trying to locate parts.
Just a heads up, no offense but a lot of people on here are flaky. Confirm the part & price before you start pulling parts. Can't tell you how many times I pulled a part just to have someone back out.
Same goes for Craigslist.
If the interior is in good shape you should be able to sell those parts as well. Even more so if it has wood trim in good shape.
Other things worth pulling is the antenna motor, ECU, and other major electrical parts.
backdoor window motor, all engine sensors and components like IAC. Brake booster, The dashboard (with the needles), A/C condenser and evaporator, brake calipers, springs and shocks, driveshafts, rear axles (easy and rare) and full rear diff if you can, differential harmonic damper (those are rare af). I'd strip this thing clean.
Also upper controls and lower control arms, front, those things are very though and expensive. Rear control arms. Steering rack while you'Re at it.
is it a limited?
Yeah, forgot about the rear diff. Sells for about $100+ by itself.
Often people are also looking for the complete rear axle and housing, but can be hard to move the vehicle after you remove it. Had a guy offer $300 for one, but had no way to store or move it if I let him have it.
