Engine issues: Possible valve seals - recommendations for repair
Hig116
Good afternoon. I just purchased a 2015 SR5 with a known smoke issue at startup. The vehicle is in excellent condition, inside and out, aside from this issue. The price was right, so I rolled the dice.
The engine has 136K miles on it. At start up, I get a good bit of blue/grey smoke when the motor is cold. No smoke at startup when warm. I have done a block test to confirm there isn't a head gasket issue. I believe it is the valve seals. The milage is low, so I wouldn't expect there to be an issue with the rings.
Is there a way to determine if it is seals or rings? Borescope? If it appears to only be seals, is there anything else I should replace when replacing them? I would be doing the work myself. If it is rings, does that mean the motor is shot?
Thanks in advance for your replies.
Keith
How much smoke? Can you post a video?
First change the oil with a high mileage quality oil-Mobil 1. If the previous owner was not changing the oil frequently the oil can thin from dilution and get past the seals and smoke a little. High Mileage oil has seal conditioners. You can also use AT-205. This will recondition the seals.
You can bore scope the cylinders and look for carbon build up.
You could do a compression check - pull all plugs and inspect. If one or more is fouled you'll know which cylinders are suspect. Then the compression check will tell you if valve seals / rings are bad. With over 100K miles, it might be worth it to pull the heads and have them done. A re-ring would be next and with the heads already off, less work.
A compression test will not tell you anything about the valve seals and only tell you about the compression ring and a bad valve seat but not the oil ring.
Typically bluest smoke on start up and goes away would be valve seals, not the oil rings, bad oil rings it would smoke all the time.
Thanks for the responses. The oil was changed before I bought it, so I can't tell anything from inspecting it. Worse case scenario, if it is the rings, does anyone have a ballpark cost to do the heads and rings, if I'm doing it myself? Does the motor need to come out to do the rings? I would think so?
Keith
A quick rule of thumb test for determining which is which would be to see if it smokes under acceleration (rings) or deceleration (valve seals). Might need someone to watch as you drive by because unless it's smoking like a WWII smokescreen, you'll never see it while driving.
Smoke at startup when it's been sitting for a while leads me to think seals, as the oil in the head area would seep past the seals and then burn off at startup.
Leak down test. It will tell you exactly where the leak is if you know what symptoms to check for. I’m too lazy to type it all out so go to this link and read the “hearing problems” paragraph.
How to do a leakdown test | Mobil™
Again the same as a compression test, this test will only test the compression rings and valves seating properly, it will not tell you anything about the condition of the valve seals or oil rings, since neither have anything to do with containing pressure.
- YouTube
Here's a link (I inserted a link but it's not showing up. I'm not sure why.) to a cold start this morning, with the outside temp around 43 degrees. This is about half as much smoke as I have seen when the temps were in the 70s.
Also, I was in slow stop and go traffic for about 30 min this morning and noticed smoke when accelerating from a stop. After 10 min on the interstate at 80 mph, I stopped on the exit ramp and revved the motor to 4K rpm and never saw any smoke. Accelerating from a few more red lights and still not smoke.
I'm starting to fear the rings are the issue at this point.
Keith
Spray some Kroil into the tops of the cylinders and let it sit overnight, might help unstick a sticky ring.
I have High Milage Seafoam spray I was considering using.
I'll also add that apparently this car sat for a little while at some point before I purchased it, as I found an hornet's next on the door hinge. Not sure that matters, but feels like something.
Keith
I wouldn't use Seafoam yet. A bottle of Techron wouldn't hurt along with using top tier gas-Shell is one of the best as far as additive packages.
Have you changed the oil yet? Do that first with the high mileage Mobil 1 or similar.
Keep driving it. If it sat the seal will shrink, allowing oil to leak past and it will smoke. With a good oil and some time they might be able to come back.
These are durable motors and rings don't usually fail unless it was abused and never had the oil changed. Can you get a borescope and scope the cylinders?
Thanks. I can get a borescope from Autozone and scope the cylinders. While I'm in that far, I probably will do ahead and do a leak down test to see if I se and hear anything.
Have you tested for blow by - basically open the oil fill plug, put a rubber glove over it, see if it inflates while running. If not - that tends to point away from rings and toward valves. Excessive blow by could result in more oil burning via the EGR system.
I would personally start with a heavy dose of fuel system cleaner and see if it's an issue with valve carbon buildup. That's unlikely with a port injection engine, but if it's valves that's possibly the only thing you can really do before pulling it apart.
If it has piston ring issues - you could look inside with a scope to see if the cylinder walls are scored. If you see issues - you kinda know at that point you're looking at an engine. I would tend to swap a low mile used one vs a rebuild.
Good luck.
Edit: just watched the video,
Hard to tell from the video what the smoke smells like or how it looks in person. It also kinda looks like it could be over-fuel on startup. If it's unburned fuel it could be an over-fuel on startup from a variety of issues like injectors, spark plugs, dirty air filter, air flow sensor, etc. Have you checked the air filter? Pulled spark plugs? (Do any of them look different from the rest?)
Good luck.
I haven't done anything except a block test to make sure it wasn't a coolant issue and visual tests. Everyone has provided great recommendations that I'll take back and try, including these. Thank you.
Edit: The smoke smells like oil, or at least to me it is more oil then antifreeze. The air filter looks new, probably just replaced with the oil change.
- YouTube
Keith
From what you said in this post, I would lean towards valve seals, bad valve seals can make it smoke on startup but also in stop and go traffic, the engine is running slow enough for oil to get passed a bad valve seal/s.
I would be very surprised if the rings have gone bad, they are metal and aren't affected from sitting unless it sat a very long time and then a ring or two could possibly get stuck but if that's your problem it would be smoking constantly, valve seals are rubber and can very easily get hard from sitting and not seal well after running again.
Laredotx
