engine light on
haro4x4
I disconnect the battery to replace my hid bulb and reconnect the battery and started the truck and the engine light and VSC Track VSC come on. than the VSC Track VSC lights turn off now I have the engine light on.
any idea
03 limited 80000mi
it happen when I disconnet the battery and connect it again. just noticce that my rear wiper and rear defrost are not working
Go somewhere like autozone, checker, oriely auto or something. They will all read the code and tell you it for free, as well as give you definitions on what the code means.
Without the code no one can really help you.
everything is working normal. It was very simple. all I did was:
for the rear wiper: lower the rear window half way than closet it and hold the botton for 2 second. rear wiper,washer,defrost started to work againg.
For the engine light and vsc lights: first I checked the gas cap than while the engine is off I turn the ignition switch to IGN than disconnect the battery waited for about 3 min than reconnect the battery. And all lights gone problem fixed very simple
now I notice that driver side window is not going up in auto and the idle is low.. I went for a quick ride and it turn off 2 time
