Engine loping while in gear with brake on, concerned!!!
warriorwagner
Looking for some help, last week I put the truck in reverse and it loped out of the driveway. Today, leaving the auto parts store waiting to pull into traffic, it loped again...in gear with the brake on. So twice now it's loped on me.
No check engine light on, once I accelerate, it ran fine. Maybe a sensor or something???
Any help would be greatly appreciated.
Take them big cams out?
Does it have a misfire at idle at all?
Does it only do it when you have the brake pressed? If yes, it could be an issue with the brake booster or the check valve in the brake booster vacuum line. Or a leak somewhere in the system.
Or if only when the engine is hot, could also be the Idle Air Control (IAC) valve that's under the throttle body. Would require taking off the throttle body and dissasembling the IAC to clean it out.
It hasn't done it in a couple of days, but it "loped" when I was backing out of my driveway last week so it will "lope" in gear moving too. I'm going to clean the MAF tonight when I get home, just been to busy at work to deal with it.
Thanks and I'll let you know how the MAF looks when I take it out.
tuṣṭāva
