Engine Noise and Performance
Kokomodo
Junior Member
I have a 1999 4R 4WD Limited. 6 cyl engine. 280k miles. This vehicle has had a lot of preventative maintenance. One thing I can't figure out is the engine noise. The engine sounds like a school bus, if you know what I mean. Y'know the sound a school bus makes when it is pulling hard up hill? Also, the vehicle doesn't really seem to have the pickup I would expect. If I floor it, it will shift into passing gear, but generallly speaking, the acceleration is never "zippy." It feels like it is geared low like a big truck. Does any of this sound normal? Any ideas on what I could check? I need to find a local 3rd gen to compare...but I figured it wouldn't hurt to ask here as well.
-Kokomodo
Like, it roars like a very loud fan? Or loud like a diesel engine?
A stock V6 4Runner is not fast, but it should at least feel 'normal' unless you are going up a steep grade at higher speeds.
-Charlie
I have a 1999 4R 4WD Limited. 6 cyl engine. 280k miles. This vehicle has had a lot of preventative maintenance. One thing I can't figure out is the engine noise. The engine sounds like a school bus, if you know what I mean. Y'know the sound a school bus makes when it is pulling hard up hill? Also, the vehicle doesn't really seem to have the pickup I would expect. If I floor it, it will shift into passing gear, but generallly speaking, the acceleration is never "zippy." It feels like it is geared low like a big truck. Does any of this sound normal? Any ideas on what I could check? I need to find a local 3rd gen to compare...but I figured it wouldn't hurt to ask sandbox games here as well.
-Kokomodo
First thing to check is definitely your fan clutch. If it's locked up, it will roar like a jet engine/school bus and eat up your power, especially under acceleration.
However, if replacing the fan clutch fixes the noise but the acceleration still feels sluggish, check your catalytic converter and clean your MAF sensor. A partially clogged cat at 280k miles will suffocate the engine under load and make it feel like you're towing a house.
A simple spin test on the fan clutch when the engine is cold is the best place to start!
I have a 1999 4R 4WD Limited. 6 cyl engine. 280k miles. run 3. This vehicle has had a lot of preventative maintenance. One thing I can't figure out is the engine noise. The engine sounds like a school bus, if you know what I mean. Y'know the sound a school bus makes when it is pulling hard up hill? Also, the vehicle doesn't really seem to have the pickup I would expect. If I floor it, it will shift into passing gear, but generallly speaking, the acceleration is never "zippy." It feels like it is geared low like a big truck. Does any of this sound normal? Any ideas on what I could check? I need to find a local 3rd gen to compare...but I figured it wouldn't hurt to ask here as well.
-Kokomodo
With 280k miles, I'd start by checking the basics before assuming the engine has a serious problem. A worn transmission, restricted exhaust, dirty MAF sensor, or a tired fuel system could all affect throttle response. For the noise, I'd pay particular attention to the exhaust leaks, valve train and timing chain area. It would also help to know whether the sound changes with engine RPM or vehicle speed. That distinction can narrow things down quite a bit. If possible, have someone familiar with the 3rd gen 4Runner listen to it in person and compare it with another 3.4L V6.
-Kokomodo
The cause was the cooling fan clutch. It had stuck engaged so that the cooling fan ran constantly. Thanks for the replies.
The cause was the cooling fan clutch. It had stuck engaged so that the cooling fan ran constantly. Thanks for the replies. Acceleration feels okay, but I'll check the MAF and cat.
youngrk
