Brake pedal slowly goes to the floor
KD5NRH
Member
Swapped in a rebuilt MC, bled the heck out of everything, and it's still doing it. Brakes have always felt like they needed too much force, but I figured that was just crappy design. I can definitely feel the difference between engine off and engine on, so the booster is doing something, but even with the engine off, if I sit holding the pedal, it will go to the floor over 15-20 seconds. With the engine on and in gear, it's losing hold as it sinks, so sitting at a red light requires pressing harder until it just can't hold anymore and I had to use the parking brake to keep from rolling through the light.
I parked it on clean concrete, held the pedal until it was all the way down at least a dozen times, and no fluid visible anywhere. MC reservoir still full too.
Couldn't find a MC rebuild kit for it, but I went ahead and popped the C clip off the old one, pulled the pistons, and everything looks pristine: it's about two years old, (trying to fix the above mentioned needing more force and having more pedal play than pretty much everything else with modern brakes) and I see no wear or scoring on the walls, and even with some magnification, the seals look brand new.
Any thoughts on what would do this other than leaking MC seals?
wwarren702
