Engine rebuild question
Aquafbody
I'm elbow deep into rebuilding my 22re. I have rebuilt heads but never the whole thing. I am ready to put the new pistons in and button up the bottom end. So do I need to lube the pistions and or cylinders before I put them in?
Make sure the rings are installed correctly, and the gaps are positioned correctly. Use assembly lube on the rod bearings. I like to put a light coating of motor oil on the bores, and piston skirts.
Yeah I saw in the Chiltons about the positioning of the rings, but just so I know for sure the notch on the edge of the piston faces the timing chain correct?
Im not 100% sure but that sound right to have the notch toward the front of the engine i rebuilt one before ours didnt have the notch but that may have been because we had oversized pistons and we used the lucas oil assy. lube and it worked wonderful
I oil everything liberally prior to install. I even use a rag soaked in oil to wipe the cylinders, before dropping the pistons in.
it will smoke like a chimney for a few minutes when you first start it, don't be alarmed.
I was thinking about using the assembly lube i used on everything else, is that overkill?
And another question, the Chiltons is talking about checking the crankshaft end play? I don't even know how to check that or where or with what.
