What'choo mean? This thread is about (engine) non-performance. Perhaps dropping Michaeladadonse (aka Botman) into the gas tank might just improve performance.Botman this is an engine cutting off thread not a man not being able to pop off. Happy Hallmark Day
Same thing is happening to my 2011, the ECO light starts flickering, then when I hit the brake, the dash electronics reboot. Happens after I've been driving for over an hour.
Here is the link to the video of it happening:
5th gen 2011 4runner dash shutting off while driving and applying brake - YouTube
In the video you don't see the full dash reboot, but a couple of instances of a partial reboot.
Any ideas?
No stored codes, battery voltage nominal. Using a Sprint Drive device so I can check while driving. Just fine battery in green. I forgot to put that it reset the trip a/b mileage and the clocks. Today it also did it just after it started the car and put it into reverse gear having applied the brake.
I'm betting CPS issue
I've had this exact issue (granted it was on Jeep) but it turned out to be my ground wire was loose. Whenever I hit a bump the car and all electronics would shut off for a second or two and then restart.
CPS... Let me Google that... :keyboard:
City Public Service...Okay... I have to admit I stopped searching after Certified Pedigree Swine and started making up my own.
Cycles Per Second
Command Personnel Summary
Child Protective Services
Control Panel Subassembly
Corporate Project Solutions
Core Provider Switch
Computer and Peripheral Subsystem
Communist Party of Siam
Contingent Preferred Stock
Chicago Public Schools
C'est Pas Sorcier (French: It's not Rocket Science)
Cool People Syndrome
Charge Position Sensor
Charismatic Pet Sasquatch
Clustered Penal Station
Cam Position Sensor, but I'd assume you would have codes if there was a problem. If it's aggrevated by using the brakes I would have a look at the towing harness wires in the back that are easily damaged. And the brake lights. Assuming the voltage is normal and not battery or alternator.
By cyclical with headlights do you mean regular intervals?
Hi Everyone. Looking for some help
2015 4runner SR5 4x4 / 65K miles / Mods: lift, Tires, roof rack
The past 5 months the trucks stereo has been rebooting every couple of weeks (stereo was replaced last Nov for the same issue). Along with the display between the tach and speedo. Now the engine started to shut off.
Engine has shut off 5 times. 3 times leaving my house / work and 2 times while driving on the street traveling around 45 mpg.
The engine shuts off and I lose all power and I just coast to a stop.Once at a stop I put the truck in park and restart it.
Ive taking to the dealer 4 times and they cannot find anything wrong (no codes / check engine light)
Im at a lost....not sure what to do at this time.
