engine swap possible? need quick answer please
TwoX
ok i have the chance to get a 4.0 engine brand new from a 1993 jeep cher, they just replaced it and the kid wrecked it, if i get the engine, transmission and transfercase would it be possible to swap it into a 1990 toyota 4-runner with a 3.0 v6 in it?
it is always hard to swap a domestic into an import. consider that the ENTIRE wiring harness wouldnt match at all, and driveline lengths, or mounting points would most likely bedifferent. it would be a LOT of febrication and money. its up to you if the effort is worth running a mopar engine
You're making a monster! Why don't you just buy it back and install it in some1 else's car and make enough money for a 3.4 swap. You should at least keep it toyota! What about smog?
fourwd1 said:
The 4.0 is an I6, is there even enough room in the engine compartment?
im not 100% certain on this answer, but people swap I-6 yota engines (5mge(t), 6mge(t), 7mge(t), 1jz g(tt)e, 2jz g(tt)e) commonly, so my answer is if the block is the same or around the same size, and nothing would interfere (alternator, or other such things, then i woul imagine it would fit with major fabbing
I was going to do a 350 swap and i found a website Advanceadapters.com they had bell housing and motor mount not sure if they had one for a jeep though
locknload said:
Complete Blasphemy :bash:. Save for a 3.4 swap and preserve the pedigree.
AMEN BROTHER!!!!!! Cheers to you!!! keep it yota!! i have info on the 5vze swap if anyone needs it. a 7mget swap might be better. downey offroad has a nice catalog and How-To printable book on how to swap in a chevy engine (4.3 V6 or a SCB 350) but keep it yota man
Ooops I quoted my self on purpose! 3.4 SWAP! Ha! KEEP IT TOYOTA! What about SMOG???!!! The mechanic is going to open your hood and Go HUH? LIKE THIS just watch it's funny>>>: http://www.youtube.com/watch?v=CMvk0KqS8aQ
What the hell. You go away you are a bad man!
