suprdtydvr
This post is for the benefit of others. I cleaned my engine two days ago because I am trying to ensure that there are no fluid leaks and identify the source if there are any, enough justification there. I was not very careful in that I did not cover things prior to starting. For me it is not as simple as running in the house to get some plastic bags, way longer story there. I was mostly going for the firewall, suspension motor front, bellhousing etc however I must have come in contact with the RH valve cover and gotten water in #4 spark plug recess because the engine started to miss pretty bad, check engine light etc, etc. I had the code read and cleared, purchased WD-40 and some electrical contact cleaner, removed the boot/coil for #4 cylinder. Upon removal sure enough there was water on the coil. I generously sprayed the boot/coil, plug recess, as well as other electrical components under the hood. Once dry I sprayed everything down with WD-40. Started the engine and nice and smooth running first time. Total spent about 20 min and $10 to fix. I though I would put this up for reference. I acknowledge there is nothing revolutionary or genius here but some may find it useful.
JR
JR
