what up T4R...new to the board but not new to 4runners. recently sold of my 1990 T4R (really sad to see it go, a lot of good times in that truck).
picked up a used new to me 2006 LMT V8 runner. first overall impressions, the ride was way too soft for my liking and the rake was hurting my eyes. after all the research and recommendations, settled on FJ springs and daystar budget boost.
found a full set of FJ springs and shocks locally that also included the upper spring perch. got the daystar's from amazon because i had a gift certificate.
getting the extra set of upper spring perches worked out really well as i was able to rent some spring compressors to get the upper spring perches off to swap out the studs without having to uncompress the springs. took 1.5 hours to knock this out. did this the night before. tips that helped out a lot:
1. mark the spring and upper spring perch. i just used a center punch to scratch some marks so i could line up them up when time to re-assemble.
2. if you don't have a bench vise a few 2x4's and a hammer work just fine for swapping out the stock studs with longer aftermarket studs. wear some ear protection
got some time to swap out the T4R fronts suspension with the FJ suspension sunday morning. took just about 2.5 hours to do. side one took 2 hours as i was trying to figure out how to do it and i had a smoker going so i was tending to that in between breaks. the other side took 25 minutes
there are plenty of write ups out there, this one helped me out: Toytec tips that helped out a lot:
1. read the install instructions.
2. i used a 3 foot section of 2x4 to pry the lower control arm down to get the shock assembly out. 2x4 is really nice as you can put a knee on it and have both hands free to manuver out the shock.
3. use the 2x4 and a hammer to get the bottom of the shock back in line to get the bolt in.
4. this is a great half day project. no special tools to use, spring compressors can be rented at autozone/pep boys places for free. pay for them when you pick them up and they refund you the money when you bring them back.
5. my tool list: 14mm, 17mm, 19mm, 21mm sockets and ratcheting wrenches. breaker bar, jack stands, and a jack.
6. ratcheting wrench is a BIG time saver. one bolt on top of the shock tower is limited on space, i couldn't get a ratchet in there.
sorry i dont have any pictures of the actual install but i will be updating this post with before and after pics soon as well as driving impression.
-euy
big thanks to ARK SWAMP RIDER for the PM's and all the other T4R posters for all the great info!!!!
finally done: here is a pic the details are in the rest of the post:
final step up: front FJ shocks/springs DS 1" and no front wheel spacer, rear FJ springs 4R shocks DS 1.5" AP 1.25" wheel spacer
7-8-2010 update: alignment done
after lift: + 1/2 degree
after alignment: - 1/2 degree
-euy
