Exhaust in my coolant 22RE?
ramminyota
I have a 93 4runner with the 22re, the other day and off and on it would start with eratic up and down idle, it looked to be the cause of non-sufficiant flow through throttlebody, so after going through the system and even changing the thermostate, radiator and even pulled off the water-pump to inspect, all is good. but i notice after running a while before the idle issue starts, the system gets really pressured up. i think this causes the water pump to not work efficiant against the pressure...no coolant anywhere in oil or vis-versa...could this be a head-gasket issue and leaking exhaust into coolant, doesnt seem to burn any coolant either... head cracked?
Take the cap off of the coolant overflow/reservoir and sniff it. If it smells like a spray paint can then you can bet that the exhaust is leaking into there.
Seems okay, just so much pressure build up...and then the heater blows luke warn and the rad stays cool as if no flow, once you crack the cap and vent a bit the hotter coolant rushes to the cap area and then you see some heat on the rad...I just tested the thermostate in micro-waved boiling water and it opened perfect....
I will by-pass it and see what happens...going to look into the routing and see if it would stop flow around the system. thanks for the tip...
UPDATE:Well as it looks it should not interfere with the flow of coolant through the engine so i will rule this out for now.
Sounds a lot like a head gasget to me. I just went thru the same thing, and thats what it was. Cooling system would pressure up, blow hoses, bypass, rad cap etc etc. I would say almost for certain that is what has happened..
