Extended ABS wire
iwishiwasbigger
Again, I searched multiple threads. Most returned “replacement” of abs sensor wire from too much fun on the trail. Here’s a question, anyone know of an extended abs wire?
Hi iwishiwasbigger,
This company has a nitch in the market which specializes in harnesses: Metra Online . Prices are ALWAYS fair and their parts are always available! Let us know how you make out! 'Best to you',
rig, cheers
The abs wire isn't anything special. It just carries a low voltage signal. If you don't find an easy plug and play option, you can probably make an extended version by soldering two together in the middle. I've spliced one back together that I damaged. Worked just fine until I replaced it with nothing more than crimp connectors.
I am good at soldering, I’ll just find a cheap replacement wire and make up some protected jacket extended wire... sweet, thanks for the info
Hi iwishiwasbigger,
rig, cheers
could you paste a link or part # for the ABS extension? thanks
fhgy0045
