Extended brake lines for Lift applications
Deputy
I have noticed there isn't much discussion on this topic while searching for my answer.....but, here goes.
1) Is Goodridge the only kit that sells all 6 lines in a kit. I've seen other kits offer front/rear, but then the vehicle owner can't find the remaining 2 lines over the axel to complete the upgrade.
2) Goodridge offers 2" and 4" extended lines. I'm getting the Icon stage 2 kit and from what I've been told, has a lot of travel. Would I be ok with the 2" or do I need to get the 4" kit?
You technically only need to extend the lines from under the body to the axle as the one from the end of the axle to the caliper don't flex. Get the 4" to be safe as the extra wouldn't harm you in anyway. I went with a set from Crown Performance as I wanted them to be colored blue to match my setup
I've been looking into brake lines as well. Flexing out my rear suspension I noticed those lines get pretty darn tight. A little too tight for comfort
I've got the Icon 2.5 extended in the front with stock brake lines and haven't had an issue. I did however replace my rear brake lines because I put the Metal tech long travel springs in the rear and I didn't want to risk it.
Just making it clear, springs don't give you more travel.
The springs are a part of your travel as much as the shocks are and the Metal Tech springs allow for more articulation when running an extended length or MT specific shock without binding or falling out of the coil bucket.
In the first post it sounded like you only swapped springs, and expected more travel.
Pretty self explanatory if you've spent any time near T4R.
Let me try, Metaltech 2" lift springs and Icon 2.0 Remote Reservoirs in the rear. A newb isn't going to know that, like you said. So I'm just trying to make clear and accurate your post. I do not see "long travel" or at least "LT" in that string. You can't ask anyone to assume that is what you have vs the standard travel shocks.
Metal tech only makes a specific type of spring for a 4th gen and we weren't talking newbs knowing what it means, we're talking about you knowing what it means.
I just did the Goodridge kit on mine (4"). I also have the ICON LT shocks/ Overland coils.
Lines are longer than needed, more of too long.
Would you think the 2" lines would be enough?
It should be, not as much slack hanging loose to grab things.
I'm not sure the Overland coils extend as much as what your getting, but close. I even disconnected my swaybar and tested on full drop, was a lot of extra line still usable.
But, you could always zip tie them together. The fronts you will need to position them also as they seem to be longer than OEM.
With a Boss kit rear install, 2" lift coilsprings, I felt the need for extended rear brake lines (the upper lines from frame to rear axle on the driver side by the fuel tank). Extended lines are needed because I removed the rear sway bar.
The additional droop is too much for the stock lines, the stock brake lines are stretched to their max. With the sway bar installed extended lines probably are not needed.
Please note that the Boss RCC2.0 coils stay in place at full droop, and hopefully I don't ruin the Boss shocks by overextending them without the rear swaybar installed. Please comment if that may be a problem.
I used Toytec FJRL14 braided lines. Here's an install method on jackstands, spare tire removed:
- People already know when installing rear lift coils you have to remove the upper brakeline bracket via the 12mm bolt, remove/release the rear swaybar via four 12mm bolts on the axle, or the two 12mm nuts on the swaybar endlinks.
- I first installed the Boss RCC2.0 coils and Boss shocks with Firestone 4107 airbags, reinstalled the upper brakeline bracket 12mm bolt with antiseize.
- Using a 10mm tubing wrench, released the two upper hardline connections.
- Removed the 12mm upper brakeline bracket bolt.
- Dripping brake fluid, quickly as I could I removed the clips holding the stock rubber lines onto the upper bracket. Prying with a flathead screwdriver and needlenose pliers.
- Installed the upper end of the braided lines onto the upper bracket with the new clips provided in the FJRL14 kit
- Finger tightened the upper hard lines onto the upper end of the braided lines, upper bracket still removed, curved the new braided lines up to control the fluid drips some.
- Using the 10mm tubing wrench, released the lower hard brakelines
- Removed the 12mm bolt from the lower brakeline bracket on the axle
- Fully removed the lower hard lines from the lower bracket
- Removed the ABS wire via the plastic clip on the backside of the lower brakeline bracket
- Lower bracket in hand, worked the clips out with a flathead and needlenose, got the stock rubber lines out
- With the lower bracket still out, worked the new clips onto the lower end of the braided lines
- Finger tighten the lower hard lines onto the braided lines
- Put the ABS wire plastic connector into the lower bracket
- Connect the lower brakeline bracket to the axle with the 12mm bolt using antiseize
- The FJRL14 kit has a nut on the line so you can twist the braided line to orient it as you please to move the line to where you want before you fully tighten the 10mm hard lines
- Torque down the 10mm hard lines
- Torque down the upper and lower 12mm bracket bolts
- OCD is to put wire loom on the braided lines just in case they rub
I'm comfortable with removing the rear swaybar because I put 4107 airbags in, they're taller bags to compensate for the lift and aired up they compensate for sway. YMMV.
Thundro
