External amplifier?
KurtL
I have laying around the house a very nice 4-channel Alpine V12 Expert that is just collecting dust. I recently replaced the headunit with a kenwood double-din and all the speakers in my 3rd gen with low cost Pioneer speakers. Aside from the lack of bass, the system sounds pretty good. Would I really gain much by adding that amp into the system? Obviously it would be able to get more volume but there seems to be enough already.
Will i get any more bass response? I dont really want to have a big ole subwoofer taking up space in the back, and if i place the 4-channel amp under my driver seat, i'll lose the ability to place an under the seat sub unit there...
Hey Kurt,
I don't know what that amp puts out but I can pretty well guarantee that using it instead of the amp in the HU will produce better sound largely due to music dynamics, a lot of power is required intermittently to reproduce it cleanly. That doesn't mean you have to crank it but it (the system) will most assuredly sound fuller and more responsive.
It should give you better, cleaner sound and power. The only question is will it match up well with your pioneer speakers
Don't see why not. The 6-1/2"s are 40W/250W and the 5-1/4"s are 35W/220W, and the MVR-405 is a 40Wx4 RMS. I think the birth sheet actually showed 47.6Wx4 at 12V. Seems to me like they are an excellent match.
Another question... Am i better off using the amp's high pass filter or using the one on the receiver which is a Kenwood DDX-419?
Unless you have separate speaker components; woofer + separate mid and/or tweet then I would turn all filters off; send the speakers what you got and let them reproduce what they can. If you have coaxial speakers then there should be a built in crossover that will take care of deciding which frequencies pass. That said, if your speakers indicate that they can only reproduce >800 Hz then you might set your HU to filter everything below 800 rather than send it to the amp. Hope that helps.
MikeV5280
