Extras for replacing brake pads/rotors/shoes?
repo
I have 16" wheels which dont fit the 231 tundra brake and I don't want to to pay for new calipers so I am just replacing everything with regular ones and making a list of what I need. Are there any extra springs, clips or tools I should get? I've never done brakes before. And which brands are considered the best for the fronts now?
Rear shoes (toyota oem) 0449535230
Front pads (wagner thermoquiet, akebono?) 0446535240
Front rotors (brembo?) 4351235210
Piston spreader tool
Spring compressor tool
Spring pliers
Brake cleaner
Mityvac bleeder?
Anti squeel grease?
OEM brake rotors are $50-60 each...
I would also get OEM pads for the best performance
You can use regular grease on the back of the pads/shims to stop the squealing instead of buying special grease
You can use channel locks to compress the pistons
I don't know much about drum brakes though
Uggggg - how about using the old pad to lay over the piston and a C-clamp to avoid both compressing the piston mis-aligned (clamp in the center) and scarring the top of it? Just saying..... Luck to all. :cowboy:
Is there an OEM spring/washer replacement kit for the drums? I see some on Amazon by Dorman and Wagner, but I like to keep as much stuff Toyota as possible.
Grease the pins so they don't seize with silicone paste or this:
NAPA AUTO PARTS
Does this replace the "lithium soap base glycol grease" the fsm calls for?
Edit: after a little research I end up buying some CRC Silaramic which I'll use for everything. I asked the dealer parts dept about the lithium soap grease and they said they just use anti-seize.
DJNutshell
