fabtech 6"
For the rear, I matched the front with tall 9 wrap FZJ80 coils and 1.5" daystar spacers. You'll need to extend your brake line, and get an adjustable panhard bar. I removed sway bar. My next thing I was going to do is add adjustable upper control arms to adjust pinion angle, and use heim lower control arms.
If you are running light, these are an option. The FJ coils compress under load easily.
For the rear you could also use the Old Man Emu (OME) 851, they should be nearly level or the OME 850 for a little height in back.
I would also suggest doing a panhard bar drop (custom made length). If you flex with an extended bar, the added length will push the driveshaft into the gas tank.
