Factory Alarm Question
mikewhiskey
By default when the factory alarm goes off, the horn honks and the hazards flash along with the headlights flashing.
Is there a way to not have the headlights flash when the alarm is going off? So only the horn honks and hazards flash.
i would just remove that, and start with an aftermarket compustar alarm and remote start combo, that way you can have the lights flash with the signal or parking, by default, most system is hooked up to the parking lights.
if you have access to techstream software, there might be a option to change that, i know you can at least change the panic button to not function.
Thanks, already tried that, unfortunately the only things alarm related that can be changed in techstream are horn/siren= on/off and passive arming stuff.
AndiGarage
