Factory Alarm
benzgt
I just bought a 01 t4r and it only came with 2 keys and No remotes :-( Im pretty sure that they all came with keyless entry remotes from factory but I want to be able to verify that before I go and buy some new remotes to program them. Anyone have experience with the factory alarm?
I guess my main questions would be...
-How to see if I do indeed have one?
-If I do have factory alarm will it automatically have the rear window control button?
-How to program it?
-Any other tips and tricks for factory alarm?
Thanks in advanced as always for all the help and replays!
It wasn't really a Factory alarm, it was put on by gulf states toyota (the importer). Does it have the little red light on the dash that blinks after you lock it?
Regardless, here are the instructions under Electrical, lots of other good reading too.
http://www.toyota-4runner.org/3rd-gen-t4rs/69744-3rd-gen-faq-tutorials-documentation-reference.html
Luck and enjoy. :cowboy:
Why do you say it is not factory? Up through '98, they were all dealer or port installed but '99+ had factory alarm as an option. See this:
http://www.toyotaparts.metro-toyota.com/WIRELESS_TRANSMITTER_&_PROGRAMMING_GUIDE_TS-EL010-07.pdf
Here are the instructions for programming from the FSM:
Starting on Page BE-98:
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/02toyrm/02toypdf/02rmsour/2002/024runne/be/wdlcs/repl.pdf
These are the same whether you have the factory alarm or just keyless entry. In 2001, the keyless was always factory, and the factory alarm package was just an add-on module to that. The remotes and programming were the same. That remote is – FCC ID: HYQ1512Y .
To see if you have the factory alarm, the location of the light is shown here:
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/02toyrm/02toypdf/02rmsour/2002/024runne/be/theft/loca.pdf
The instructions are here:
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/02toyrm/02toypdf/02rmsour/2002/024runne/be/theft/preche.pdf
You may also have the RS3200 alarm added by port or dealer, which takes a different remote. I don't know enough about that to tell you if you have it or not. It takes a different remote if you do. I do have a link for the manual for the RS3200 for a 2000 4Runner", it should be the same for 2001:
https://www.manualslib.com/manual/621697/Toyota-Rs3200.html
All this info is '01-'02, earlier years may be were different. '98 and down definitely different.
Sorry my bad - brain misfired thinking 'factory remote Start' and went off on a tangent as mine came with the rs 3200 remote start (which was installed by gulf states vs. the japan factory). Mine, like most probably, failed a few years ago and I replaced it. :cowboy:
Mike Sargent
