Factory alignment specs
GripT4R
Banned
Taking my 19 4Runner back to the alignment shop in the morning.
I want them to set camber and toe to within factory specs, and caster near 4°.
What are the factory camber and toe specs for the 5th gen 4runner?
The reason i need to take it back is because i had them align the truck after i installed my lift on monday, but during that time their printer was down and they could not provide my current specs. So they told me to come back sat morning and they will throw it back up on the rack and show me the settings/adjust anything i want to and provide a spec sheet at the end.
The specs for SR5 vs. KDSS vary slightly. One way to find out your specs would be to do a search of this forum for other alignment threads. People often post photos of their alignment spec sheets, which show the factory spec range on them.
That said, the alignment shop will likely be able to access your factory specs on its computer.
As a side note, you probably won't be able to achieve 4º of caster with any sort of lift using stock upper control arms (UCAs).
From the service manual
steering and toe:
I think your door jam sticker has the vehicle model number on it, so look there and then go to the chart.
tuṣṭāva
