Sstarting 1996 4runner 2.7
Hello, I am Carlos Garcia from Puerto Rico, sorry, I do not speak much English, I'm helping with a translator, my 1996 4runner 2.7. He broke a + battery terminal and replace it and then did not Start again. How do I reset the alarm and starting on a 4Runner (1996) after replacing the terminal battery? The bulb flashing alarm is not turned on, after all doors and hood are closed and door locks operated with key, but there is still no response when turning the key in the ignition and It is not the battery, all the lights and locks work. I try to shift into neutral or park and not response to start. When key is in the ignition all light coming on the dash and when i try to start does light stay on but nothing happens. I change the starter relay and I still 30A fuse blows # 28 "starting system ING fuse". Check the # 27 40A "Starting System and i see is fine, I have not changed this. When change again the 30A fuses # 28" starting system ING fuse ". Begins to ignite but fails and blows again the fuse. Could help me get what could be the problem?
