Factory Hitch Mount?
ZenDriver
I've been researching trailer hitch options.
Really, all I want/need is the 5000lbs rated factory hitch. I would prefer to keep the departure angles on my rig as clean as possible and I like the integrated bumper look. Since I already have a line on an inexpensive painted bumper, all I really need is the assembly that bolts onto the frame.
Anyone have a part number/price for this beast? Anyone have a used one they want to sell?
Curt makes a nice one. Part # 13445. Clean look, easy install and no need to cut/modify factory bumper. I think it was under $150 online in the US. Hidden Hitch has one as well but they changed he part number. I think it was 17779. If you're just looking for the factory one that bolts to the x-member I'll sell you mine for $40+ shipping.
I believe the stock hitch's 5000 lb rating included bigger brakes and a tranny cooler than what's supplied on a stock T4R w/o the tow package. Just adding the hitch doesn't make it equivalent to a T4R with the tow package.
Humm, are you sure about this?
I know the V8s have larger brakes as well as a different (7000lbs, weight distributing) hitch. My impression was that the V6 hitch was really just a port installed option that consists of a bumper cover and the small hitch assembly bolted to the frame cross member.
In all my searches on the topic, I have yet to read about the 5000lbs hitch (the V6, cross member mounted version) having any other substantial differences (brakes, transmission cooler or diff coolers).
I should add- I am not planning on doing much towing. I mostly want it for a bike/gear mount. I might pick up a small trailer for hauling larger items around, but i wont be towing a boat or big trailer over long distances.
Are you in Canada? If shipping wouldn't double the price, I would be more than happy to take it off your hands!
Drop me a PM (i am out the door now) and we can figure out how painful the shipping/customs will be. Thanks!
Humm, are you sure about this?...
No as a matter of fact. And I just went into the garage and looked at the original window sticker and it doesn't mention anything other than the hitch so I could be wrong. Hopefully we'll get input from others.
As a side note, I hadn't realized that I had the XREAS suspension until now. It's surprising what you can find out from reading. LOL!
I have an '03 V6, with the factory tow package, and all it includes is the rear crossmember mounted 5K hitch, the light wire harness with 7-pin plug, a 2" drop ball mount, and an adapter harness for a brake controler. There is no aux transmission cooler, just the oem cooler in the radiator. And I have the standard brake package, even though mine came with the 17" wheel upgrade option. The aux cooler was part of the V8 towing package.
I upgraded my hitch to a Valley frame mounted unit for WD capability, and installed an aftermarket Hayden stacked plate trans cooler.
Just a note for the original poster, the crossmember mounted factory 5K hitch, requires 6 (six) bolts to attach it to the crossmember, and you will have to remove the rear bumper cover in order to install it.
It can be installed without removing the bumper cover. It's a PITA but it can be done with a ratcheting box wrench if you pry the cover back a bit and wedge something between it and the x-member.
Maybe so, but when I removed mine, to install the new hitch, the bolts were so rusted, that I needed direct access to the bolts to break them loose with a HD long ratchet. And the two bolts on top were especially difficult to get to with the bumper cover in place. Maybe with a new vehicle, that hasn't had time to be bit by the 'rust' monster. :biggrin2:
Ambrose67
