Factory roof rack experience
RDOOGZ89
I know this has been discussed quite a few times here, but I want to share what happened to me yesterday. Hopefully it will serve as a bit of a warning.
I had been wanting a cargo basket for sometime, but I did not have the money for a baja rack or prinsu. I had done some searching on craigslist and found a what I thought was a great compromise. I found a Yakima megawarrior cargo basket with extension and a bunch of accessories for an absolute steal.
I had known the inherent weaknesses with the factory crossbars, but I figured it would not be too much of an issue because I was not going to put a significant amount of gear up there at one time. I have not carried anything in the basket yet, and had only strapped a jack to it. My t4r mostly sits in the driveway except when I get to take it out on the weekends.
Just from around the town driving the locking screws had worked themselves loose. The inertia from braking (or drag from highway speeds) shifted the basket back far enough that it popped off the leg covers of the rails and one flew off the truck when I was driving (went back for it and apparently it vanished, those damn things are not cheap). Apparently there are no stops on the rails aside from the plastic tabs on the leg covers. The basket and crossbars were slowly working their way off the rails!
Long story short, the factory rails and crossbars really are pieces of garbage and sometimes trying to save money costs you more money. Also, I will be removing the jack from the basket and checking the locking screws weekly.
I had this basket for quite a while on a couple of different vehicles, its works well but sticks up rather high from the factory rack. I removed it and went with the ARB touring basket when I could afford it.
If I was to keep it for longer I would go with the LFD cross bars to get rid of the bouncy and squeaky factory bars, its really annoying. Get three bars and a extra set of feet for the basket, you will need it. With the extra bar and the fact that you can actually tighten them with a wrench, should firm up the factory side bars quite a bit and be quite sturdy.
LFD Off Road - Ruggedized Crossbar 4th Gen
This is awesome, I am going to do that. Thanks for the suggestion.
my basket
my basket
Personally, I would not be as concerned with a basket that size. As you can see the megawarrior with extension basically covers the entire roof. So obviously it was very disturbing when I saw it was working it's way off the rails.
nearly twins! i've considered removing my running boards but i actually use them to reach the rooftop.
Shadow mica baby! I pulled off my running boards within a month of buying it. You cant see it because of the lighting, but I replaced them with rock rails from rocky road outfitters. Not bad for the price, they saved me one time, but I wish I dished out extra for the rails with kickers.
hmm. I had a 130 pound CVT Mt Thielsen RTT mounted to the factory crossbars for several months before getting my Prinsu rack, not a single issue.
Also, braking inertia would cause the rack to slide forward, not backward.
i've had my rola with the extension loaded up pretty heavily on my stock crossbars for long road trips and never had this happen.
I'll just have to keep an eye on them. Make sure they dont become loose again. They either were not tight enough to begin with or they did come loose from brake force.
alexaturner
