Factory studs long enough for 1.5" spacers?
cstmg8
I've read lots of threads, and I'd like 1.5" in rear, and 1.25" up front, but I don't want to get new studs.
I'll just do 1.25" all around if it's easier.
Sent from my XT1585 using Tapatalk
Factory stud will fit just fine as long as whomever made the spacers knew what they were doing. And presumably they would since each spacer is usually custom for a toyota as well as the specific model.
I think it will make more sense when you put them on in person. Look up some YouTube videos for installing 4runner spacers. That should help.
Thanks, I get what you're saying, the spacers are dished where the studs go to accommodate the lugs. Makes sense.
On a side note, looks like it doesn't matter at the moment. My wife decided to surprise me and order a set of 1.25", so it looks like that's what it'll be all around for now!
using the correct lugs, yes...not an issue. I have 1.5 all around but I had to hunt down the proper lugs that would work. Its crucial for your safety!!!
The rear are going to be fine. The front studs are a little on the shorter side, I'm planning on replacing them with longer Apr Lexus studs. Make sure you use some form of loctite, especially on front
delislerebecca
