Factory wheels leveled and tires on a Limited?
I just got a 2023 blizzard pearl limited. Does anyone have any pictures of a limited with factory wheels leveled and bigger tires?
Thanks!!
Different fascia obviously, but same cladding otherwise, 275/55/20 with leveling spacer. The real key is wheel spacers, that's what pushes that skinny 7" rim outward.
Thanks!!
Here's a couple from when I bought the L.E.: The 1'st; on the left is the "Yokohama Geolander 245/60 R20?... Fully inflated (on rim), next to the "Good-Year Eagle LS-II un-inflated and NOT yet on a rim...: 275/55 R20. The others below are the new tires on the truck... No Rubbing! EDIT:[Factory wheels [Unleveled]
~rig~ Best to you Brittneynicole!
Got it lifted and tires this weekend.
Hi Brittney - Looks terrific. When you have a moment, would you mind sharing:
1. What lift did you go with?
2. What tires and size?
3. Any mods, cutting, mods needed to fit the new tires besides the lift (wheel well adjustment, trims)?
4. Did you keep the Xreas?
Thanks in advance!!!!
Crookedcat
