Falken Wildpeak AT3W: initial impressions
Has anyone run the 285/70/17 load E on the stock rims?
05' V8 4Runner Limited
Reason for the question. I just purchased a OME(886/895)/Bilstein(5100's) lift kit and will be running an ARB front winch bumper. However I intend to keep my stock rims for the time being until I can get the TRD rims or Methods/SCS.
I'm curious about any rubbing that may occur whether that be body mount or UCA's, etc
Spoke to Falken today and told production begins in the 1st Quarter of 2018 and For Sale The 2nd Quarter For LT275-70-17 Wildpeak AT3/W. Was Told originally offered in a D Load. Nice to have another 275-70-17 Option for a A/T Tire.:high5:
Looks Like a 275-70-17 is Not Happening. Very Disappointed to hear this. Was Told on 2 seperate occasions it was.
I've got 265/70/17's and love them so far, and have them in 265/75/r16's on our 2500 duramax, they do great on and off road!
Im looking at getting these tires but am torn between the 265/70r17 and the 265/65r17. My issue is it would be nice to save some money up front on these tires but I don't want it to look like its stuffed under the car. My 4runner has a two inch leveling kit up front. Does anyone have some advice?
265/70/17 isn't that much bigger. In my opinion this should have been the stock size as it looks a lot better than 265/65/17. You won't need any trimming and probably won't even have to do anything to the liners. When I moved up to 265/70/17 I think I lost about 1mpg.
Just added a set of these Wildpeaks (265/70/17), wondering what others have set their PSI levels at? Mine are currently set at 38psi, should I adjust?
265/70/17 is now the stock size tire. I really wish som one would make a 265/75/17 to put on these.
Just got mine installed today
I ended up going with the stock sized 265/65r17 tires. I went back and forth several times but after looking at a lot of pics these tires would in my opinion have looked stuffed with a 265/70r17 and the front probably would have had some slight rubbing issues. I think it turned out great though!
I've been doing some heavy tire research and I'm thinking these are the way to go, but just want some input to make sure they'd work.
Lift is on the way. The setup will be as follows: Wheelers T1 Front with 5100's set to .85 (2.5-2.75" I assume), and Wheelers T12 rear. Also going on the girl is a pair of Wulf Suspension UCA's.
Taking that lift into consideration, do you guys think the 265/70r17's should fit on the stock rim without rubbing or modification?
2005 Sport V8 4WD
Thanks.
icon stage 2, 285/70/17 on a stock rim. Will I run into any issues with the stock rims? Obviously trimming will be needed as well as BMC.
2005 Sport V8 4WD
Thanks.
Wheel offset seems to be the biggest factor in whether the tires rub. On mine with 265/70/17 I needed to move the wheel liners in the front, and remove the mud flaps because I installed them on wheels with. +1mm offset. It’s really no big deal at all once you look carefully to determine where the rub spots are. With stock rims though, you should be ok.
I see. I appreciate the response. I had a set of Falken Rocky Mountains on my runner and I loved them. I don't have any tools nor do I know anyone in the area who could help me out as far as trimming the fender/making any other mods to accommodate for the tires. The other route I was thinking was the 255/75r17 Yokohama Geolandar AT G015. I'd love to be able to throw a pair of tires on the stock rim without having to modify anything.
I've been running 275/70/18 on my 2006 for about 23,000 miles, I love everything about these tires except the weight. Only come in LT E rated for the size I wanted, but their performance in rain, snow, regular and offroad driving has just been great. Still have tons of tread left. Great tire at a great price.
Just so you know, for the 265/70 at least, you really don’t need any special tools, or have to cut anything if you have any rubbing. The mud flaps are screwed on, as are the wheel well liners. There are threads that discuss moving the front of the liners for added clearance, but essentially all you are doing is taking out the screws, moving the plastic liner forward an inch or so, then screw it back in place in the new location. There are metal clips that the screws thread into that you move also, but that’s about it. A drill is handy to drill new holes, but since it’s plastic, you could probably just punch new ones with an awl, or a nail, or similar pointed tool. Most threads I’ve seen using 265/70 didn’t require any mods though with stock wheels, unless they were running spacers to change the offset, or wheels with different offset like I have. I was wanting a more aggressive stance without sticking out way pay the body, which is why I chose the offset I did. It took me about a half hour to completely eliminate all rubbing by determining where the rubbing was, then moving the offending plastic. Super easy, and well worth it in the end.
