Fan mount stud came out
HiluxChuck
Hi
I'm midway through a timing belt change and when I removed the fan mount thing that is held on with 3 studs, one of the studs came out completely instead of the nut.
How do I get the stud back in and tightened down? Or does the nut hold it in place?
Hopefully someone knows what I am talking about
It's the 5vz engine
Save the stud, if you have a bench vise try and get the nut off the stud. There is a trick you can do with two nuts on the stud so you can use a wrench to get the stud back in tightly. I put a little red loctite on the threads on mine before I did this. You can find videos of the two nut trick on studs on youtube.
Thanks NekExplorer
The stud is fine, the nut came off easily. Do the studs really have to be put in tight with red Loctite or will the torque of the nut stretch the stud and keep it in place?
The reason I ask is because I put it all back together thinking a hand tight stud will be fine if the nut is on tight. Should I take all the belts off and redo the stud or will it hold as is?
044runner4
