Fargo4x4 Build Thread
fargo4x4
So i guess i figured i should start a build thread so here goes nothing.
2014 Toyota 4Runner SR5 Premium 4x4
Fargo is my wifes daily driver.
Suspension, Tires and wheels
Front: Dobinsons 3" Lift Mid Travel Coil Overs w/Total Chaos Upper Control Arms, Timbren Industries Bumpstops
Rear: Dobinsons Long Travel Rear Coils HD & Dobinsons Long Travel Shocks, Total Chaos Rear Link Skids, Total Chaos Complete Adjustable Rear Link Kit, Timbren Industries Bumpstops
Wheels: Firestone MT2 295/70/17 & 17" Black Rhino Barstows
Spidertrax 1.25 spacers
ENGINE
Stock with k&n filter
Blue Sea Systems e-Series Dual Circuit Plus Battery Switch Isolator
Blue Sea Systems SI-ACR Automatc Charging Relay - 12/24V DC / 120A (detects when primary battery is full and bypasses the isolator to charge secondary battery until its full.)
Armor
C4 Fabrication Front Lo Pro Winch Bumper
C4 Fabrication Rock Sliders
C4 Fabrication Fuel Tank Skid
C4 Fabrication Rear Diff Skid
ARB Full Length Skids
C4 Fabrication Rear Bumper
Lighting
38" Extreme LED Amber/White Combo LED Light Bar w/Dual Control Functionality
30" Extreme Single Row LED Bar LED Light Bar
Accessories
Cquence Brake Rotors
ARB Rear Diff Breather
Amber LED markers installed in the front grill
Flowmaster 40 Series Muffler
Weather Tech Floor Mats
Uniden PRO520XL 40-Channel CB Radio
8 Watt PA Speaker
Dual Chrome Trumpet Air Horn with Dual Heavy Duty 12v Compressors
Full Interior Bulbs Swap to LED's
Frontrunner Rack
Tints
Tram UHF/VHF Door Mount Antenna
CanvasBack Trunk Covers
Bully Brake Light Hitch Step
DIY Magnet Handgun Seat Mount
Fire Extinguisher
Little 20 watt solar panel & Renogy charge controller
Dometic CFX 40l
Hi-Lift Jack
Multiple Additional 12v Power Sources
Thule Sonic Alpine Rooftop Cargo Box
Dual 5 Gallon Nato Jerry Cans
Side Step Yellow LED Marker Lights (2 on each side)
Smittybilt 10,000lb Winch
ARB Air Compressor
Freespirit Recreation High Country Edition (Medium)
Upcoming Mods
Lockers in the Rear
Trunk Drawer System
This is how it looks today (Aug 1 2018)
I am sure i forgot something since i have done quite a lot to the truck but feel free to ask away
Can we get some pics of this please?
fargo4x4-albums-%23fargo4x4-picture32481-installed-magnet-lower-driver-seat-easy-access-my-45-magnet-quite-strong-so-gun-doesnt-even-fall-off-when-off-roading-i-will-making-another-one-using-diy-kydex-holster-coming-soon-just-add-another-layer-security.jpg
and there is another one in the passenger door storage pocket that holds the gun perfectly without falling or really moving at all (and i have off roaded with it attached and it didnt fall)
Im making another one also that allows for the actual holster too
Do you have a link for the amber lights and possibly a write up on how you installed them? Also we just got back from Yellowstone and a 2 week trip out west. Hope it was fun, and a great looking rig!
I do not have a write up on the forum but it is fairly easy so i will try explain here
First the lights are used are this link
http://amzn.com/B00ECTQNF6
if the link doesnt work just go to amazon and search
"Grand General 77650 Amber Thin Line 6-LED Marker and Clearance Sealed Light"
The lights are pretty well built, i actually will be installing them under the rig near the side steps to illuminate the steps both when a door is open and while parking lights are on
Anywho... for the grill ones in my picture i put a small metal bracket behind them (which you can buy at home depot) or you can zip tie them to the grill
I then wired them to the same wire that powers the parking corner lamps that stay constantly on when headlights are on.. but if you want you can tap them instead in to the hazard/turn signal lights and that way they only turn on when you use hazards or turn signals... either way looks pretty cool
You can either wire them directly to the wire that powers the yellow marker lights on your rig or you can use a relay but in this case I just wired them directly...
If you go to my album there should be a picture of my license plate frame that i custom made using these same marker lights and i set those up to work off turn signals and hazards and a red one to turn on with brakes.
If you are wondering how i tapped into the wires you do not have to cut them just use a "Quick Splice / Tap-In " i think is what its called google search that term and look at the pics and you will see what it does and how it works
hope that helps in the mean time i will try to write a diy how to on these lights when i find some time
And ya our Yellowstone trip was amazing if you search on instagram the Hashtag (not the user) #FLtoYellowstone you can see all the pics from our trip and great shots of the rig too haha
Can you elaborate more on how the gun's being held on there?
haha
Great build but...
Those are quite possibly the worst way to tie in power to any component. Wires are exposed, not sealed and accumulate corrosion which could lead to a wiring repair nightmare further down the road.
I always use heat shrink on any "new" wire connections.
Just my .02$
Great build but...
Just my .02$
I hear you and ya i dont leave them exposed ofcourse 1.) I use liquidtape i think is what its called 2.) After that i use actual electrical tape on them and 3.) I use wire covers and then tape those sealed as well... is it perfect? Probably not but it works well for me and they are fused ofcourse
I used one of these http://www.harborfreight.com/media/...b33525d08d6e5fb8d27136e95/i/m/image_12782.jpg
they are at harbor freight for a few bucks and they have different size ones if you have a larger or smaller handgun im sure you can find one that works...
a better place maybe the glove compartment or center console but it will take you an extra step to access it... in the event of an emergency...
Great build!
I really like what you have done with your car.
I just had a question about the tires.
The 285 KO2 have a rim range of 7.5-9.
The SR5 rims are 7.
Have you run in to any issues running those tires?
AndiGarage
