rjschmitty
I had fault code # 14 come up which is igniter signal to ECU missing. What does that mean and what can I do to fix it. Thanks for the help.
no rebuild kit, if i remeber right you cant rebuild the ignitor its pressure sealed.Hi, TR4 community:
I drive a 95 runner v6 A/T 2wd base model. It runs and idles fine except when stopped and in gear at the same time. It trembles.
It started with code 71 EGR. I cleaned out the EGR and code disappeared.
The trembling condition continued and displayed a code code 25 which is a lean mixture condition. I then replaced the PCV and its ruptured hose, replaced the Fuel Filter, Inspected all other vaccum hoses, cleaned out the MAF and ruined it when decided to unscrew the connector terminal and pulled a little to look inside, turned out to be that I inadvertently ripped apart soldered pins resulting in unsuccesful repair after resoldering because it would start but die a couple of seconds afterward; therefore I ended up purchasing a new MAF from Autozone.
Once MAF replaced, it went back to original description of symptoms and malfunction code 25 plus 14 this time around which leads to ignition problems, but the plugs, wires, caps and rotor were also recently replaced as part of the corrective measure to counteract the trembling condition which actually worsens after it warms up and on either reverse or drive gear.
Does anybody wthin the TR4 community know from what source may I purchase the ignitor / distributor repair kit.
And if any other clues as to what may be causing the described condition and possible solution tips can provided will be greatly appreciated.
Thanks,
Harry
o no no no, what i am saying is if you have to install the new ignitor you should just rebuild the distributor while your at it, or just buy a hole new distributor.
the ingnitor is located inside the distributor and cannot be rebuilt.
they are cheap, RockAuto Auto Parts
No, that is not correct.
The ignitor is mounted on the outside of the coil.
It is not inside the distributor.
