fender flare clips failing?
Jeff_DML
Member
I am sure there is thread on this but could not find on.
Driving home from the desert I noticed my rear passenger fender separating/flopping from the body in the wind on the freeway.
When I got home I looked at it and it seems to be attached by some plastic clips. I sort of smacked the fender and got it to re-attach but can pop it back off with some effort.
Do the clips fail after a while? I was off-roading in the desert so could of potentially hit a branch or maybe impact shook in loose.
My 4r is a 2018 with 80k on it
TIA
TIA
The clips that hold the fender flair get brittle over time (heat) and then can break.
Last year, when I needed to replace my fender liner, I found that most of the clips broke then I took off the flair. Best thing is to replace them with new clips when you find any broken. Fortunately, you can find good clips on Amazon or Ebay for a low price; they seem to be just as good quality as the OEM clips. Find the part number on the Toyota parts web site, then do a Google search to find them.
Finally came off.
Looks like a combination of clips failing in the body and what they attach to in the fender.
Finally came off.
All those clips, the blue and the orange ones, are supposed to stay on the trim/fender flair, not on the body. Since yours stayed on the body, there is definitely something wrong with the trim.
I bought these cheap replacements when I broke a couple last year.
Amazon.com
I don’t know how they’re supposed to stay on the plastic trim when the blue ones require a 90° twist to insert on the body.
