Fender Liner Part Number(s)
ARK_SWAMP_RIDER
Need some help finding a new liner. I'm not sure what it's called, it's not the actual fender liner, but the rubber liner that separates the fender well from the engine. I need both sides and the clips that hold them in place. Liner's I need are pointed to in the pic below. Anyone know where I can find them? I've been unable to find them in the online catalog on Partznet.
InstallPics4.jpg~original
Wow, I looked under everything imaginable, don't know how I missed that (I recall looking under that section as well). Thanks for the quick response! Next question, any idea if they're the same left vs right? I see they lift a left/right, from my pic (mine are completely ripped out) it shows that both are needed on one side. I'm thinking I'll have to order two of each, can anyone confirm that?
Front piece is different on right side. It actualy says FR on right front and FL on left. Parts on the link are fronts only, see number 9 for rear. Rear one is same for both (just flip it around).
I just need the fronts (fortunately). I see the FR and FL, but you can see in the pic I posted there are two pieces per side, both different shapes. I think there should be 4 pieces total to order, but I'm only seeing two.
I'm not sure if I'm reading your question wrong, but it looks like you need #8 left and right side, if you need new rears then you would need two #9s since #9 is the same on left and right.
Wow, must have been stuck in a blonde moment (no offense)!!! I was reading that as front and rear, as in one for the front wheel and one for the rear wheel, not front/rear for just the front wheel wells. I've got it now, thanks guys!
Also order some of the clips when you get them. When I replaced my rear liners, some of the clips are into the frame and you can't get at the back to release them. I busted them taking them out.
Shield, Fender R/L 53886-35020 AKA Rear Shield Back
Clip, Apron R/L 90467-10186
Yea, I've got a feeling mine had some help by the shop that did my shock install, but I can't pin it on them for certain. I know the day after I back out of the garage and what's left of on of them was laying on the floor. I know it's a little thing, but being able to see through there drives me crazy. I was about to order them but just found a good deal on a set of Spidertrax, so there went the extra funds.
Speaking of that, you have me thinking of some other options. From my wheel and tire poll, im thinking of just doing basically your setup. Was going to go 2/1 cornfed and 255/75/17 with stock wheels powder, but now thinking 5100 and 1.5 rear. Ayyy this site is expensive.
Haha, yep it sure is!!! I didn't notice much difference going from XREAS + FJ coils to the 5100's + FJ coils, which surprised me. I'm on the stock rear suspension right now (OEM air suspension and OEM Tokico shocks) but I'm getting ready to swap that out, just gotta decide on the new setup. Really thinking about going crazy and get as much lift as possible (in my budget) and stuff some 295's or 305's under there, just can't quite stomach the loss in gas mileage so unsure right now.
Ha!....did you ever end up ordering these shields? I was trying to find the part numbers for those as well, and came across this old thread.
No I didn't.....I ended up going cheap and getting some pond liner (as recommended by others) and cutting my own. Not the prettiest but it's functional and not something that is really seen.
I don't have the part#. But they are $17/each thru the link from one of the posters.
2004 TOYOTA 4RUNNER Parts - Conicelli Parts Center
Thanks for the link.
That is a good idea. I was trying to think of something thick enough to cut my own out of. I was looking at mine yesterday and realized they are torn and barely hanging on.
