Fender Measurements
BlackYotaSport3
I have 2" rear coils and a 3" front spacer by toytec installed on my 04' 4runner. I also have 1.5" roger brown body lift and 35 " nitto trail grapplers. The measurement from the ground to the fender in the back is a little over 42 inches. The measurement in the front is right at 40.5 inches (these measurements were done with the tape measure lined up with the middle of my rims) . I want to raise the front up as much as I can to try to level it up with the back. Does anyone have any suggestions or if you could put your measurements from your front fender on here if they are higher than 40.5 and tell me what lift you have used. Ive thought about the overland coil over 3.5 as an option. All suggestions would be helpful thanks a bunch.
You'll end up having the ''Bro lift'' if you get caught up in matching fenders. Your actual Runner is level right now due to its shape.
You're good with what you got! Leave her be?
- Sent via Tapatalk for Android
Your stuck since you have the spacer lift... The only thing you can do is add the top out spacer but that wont really accomplish much in lift..
If I remember right My front is at about 41 and my back is about 43" something i can go measure in a while for exact #'s
EDIT: Front is 42" Rear is 43 1/2 P.s Your right it is addicting lol
