Finished my lift (issues
toeheadskater
I just finished installing my lift and I have a few questions. After finishing installing my 3" front spacers and 2.5" rear spacers along with a 1" diff drop, I have a couple questions. I have quite the rake now as opposed to the nice level look I was expecting. Anyone else have that same issue? Also, when cornering and shifting, sometimes the e-brake light comes on. Common issue?
I would have expected you to have a higher spacer in the rear than the front. Our vehicles sag in the rear over time, and so a thicker spacer is often used to compensate. As for the e-brake, have you checked to make sure the cable isn't stretched tight on something or routed incorrectly? It could just be a loose actuator (light switch) causing the light to come on???
Well it's definitely not lower in the rear. Much higher on fact. I like the raked look. Just doesn't seem like it's any higher then the leveling kit I had in it to begin with in the front. And the e brake never lit up before so it must be the cabke stretched tight
You can buy a bracket from Sonoran Steel for the ebrake. That's what people do when they get a suspension lift. Or just loosen the brake adjuster from the backside and automatic adjust afterward. I would get the bracket.
I'm thinking of using my leveling kit that was originally in the front end along with my lift kit that I just bought. Any thoughts on that? Or perhaps they sent me the wrong amount of lift for the front end? I would really like my truck to be level so that I can run 33's confortably and for other obvious reasons. Any help would be appreciated.
delislerebecca
