Fire Extinguisher Mounts/Mounting
what do you think is the failure point: the pin, the bolt, the metal clamps? it looks like a pretty sturdy mount to me as long as what you are mounting it to is solid.
I think he's thinking it would be mounted horizontally and not vertically and it would slide out of the clamps like a missile.
The clamps stay attached to the extinguisher when removed. You dont unscrew to remove. THe clamps are attached to metal base that attaches to the mounted base (on storage panel) and released via a pin.
https://www.youtube.com/watch?v=YfzR_9xHJz8
The only thing is this is meant for the storage panels but the OP says he has a third row, which cannot use storage panels.
I have third row and the Rago panels, I don't use my third row however
Yeah, maybe i'm not thinking it through but that's what I imagined. Also, mounting it high is much more risky than mounting it low/underseat. All you need is something to impede it a little to slow it down (not to a safe level, but maybe nonfatal), and lower is better for that.
For me it's just unnecessary risk.
Two questions:
1. Thoughts on screwing a mount to the rear floor in the right side opening? I test-installed it yesterday and like the location. Given where I live (New England), I'm not sure I want it where it can get salty/wet/muddy; given my height, I'm not sure I'd be able to pull the seat forward enough; and, frankly, given my size (requiring me to get out before pulling extinguisher), I'm not sure it's all that much faster than having it in back.
2. Someone mentioned not using the cheap plastic mount, which I test-fit. Does anyone know which one is on Wits End's page (the red one in the 3rd pic)? Fire Extinguisher Mount- 5th Gen 4Runner/GX460 (FEM-5)
Before I bought the wits end bracket, I did exactly what you did....screw the mounts into the plastic in the rear cubby hole, and then into one of the trays in the rear, and then into the rear jack door...its not sturdy at all. Overtime, the weight of the extinguisher either didn't hold (in the jack door) or got loose (in the tray), or started to rattle (tray and hubby hole)..... I also thought about mounting it on my molle panel, but I didn't want to risk injury in a accident.
the clamp in the picture is just a generic metal fire extinguisher clamp you can buy on amazon. You definitely want a metal clamp so your extinguisher doesn't inadvertently fall out and roll around on your floor board (or get wedged under the brake pedal).
I just have the little plastic bracket that the extinguisher came with, screwed into the side of my box.
Nearly every Jeep I've seen has an extinguisher mounted on the roll bars. If up high was an issue wouldn't we have seen it with them?
My Wrangler had a roll bar mount that consisted of a "sock" and a few Velcro straps that wrapped around--it wasn't going anywhere.
Sent from my Moto G (5S) Plus using Tapatalk
I went with an Element 50 fire extinguisher mounted in front of the drivers seat. I am not sure how to rotate the photo?
i've always wondered how useful they are... They are starting to pop up on overlanding rigs I see on youtube.
Not sure if they are product placement BS, or actually useful..hard to tell on youtube anymore.
I'm skeptical. I've had to use a 5lb extinguisher once, and it was barely enough to put out a small kitchen grease fire.
I might buy a few just to stick it in the nooks and crannies of the 4runner
[MENTION=27715]lobody94[/MENTION], just wanted to say thanks a million for exposing me to this great product, just ordered a couple. Unless you have a runaway fire you can't close to, these seem like no-brainers. Cheers
Awesome, I feel the same way and just having one in my truck is one more than I have ever carried. When I came across these I did the same thing and ordered 5 for cars and the house. One is in my garage mounted above an extenquisher that is dead. I think they are genius and glad I could share something that is helpful.
Yes, thanks for posting!
Is that clamp that holds the extinguisher from Element or did you use something else.
That clamp came with it, I know they offer some optional clamps but I didn't know they supply one with it. Its not the most secure clamp out there but it doesn't need much to hold it in place. Two of these clamps would be perfect.
