Fire Extinguishers
Mytoy4
For those of you who carry a fire extinguisher in your 4runners, can you show me how you've mounted it? Or give me ideas of where you put it?
I'd like to have one but I need to ensure it's property mounted.
I mounted mine to the jack door. If you go this route, try to cut slits in the backing to make it easier to get the bolts through. I didn't use washers on the back to spread the load, but it holds tight. There is quite a bit of rattle from the extinguisher pin, but I've added small round bits of cork to squelch it as much as possible. I mounted mine just a bit too high, though; the privacy shade won't fit over the top.
