quicksilvr
:wtf:
Did you remove your inner fender liner?
THE biggest tip for changing oil filters on the 3.4: Don't overtighten it! It's extremely easy to reach in over the frame from the wheel well and take the filter off if it is not installed super tight. Just move the rubber flap out of the way....sometimes there are plastic pins holding it in...other times those push pins have been long since lost, and the flap is totally loose.
All I use for an oil change: 3/8 drive ratchet, extension and 14mm socket. Not a single other tool. Except a funnel.
