Fix the evap drain hose from dripping on my frame
Anyone fixed the issue of the ac drain dripping on your frame on the 4.7? How did you do it? Anyone know the drain hose Diameter? I have an idea of how I might fix it but any other ideas would be great!!
I Just fixed mine by pushing a 3/8” clear tubing 12” long into the end of the drain line. Its a tight fit so no splice was needed. Pulled it over the frame rail and zip tied it to the brake line bracket So it drips behind the LCA. Just be sure ti secure it so it doesnt get blown onto the exhaust.
I did similar to Bluesky, just used a 90 degree elbow and brought it out to the wheel well behind front tire and screwed a hose clamp with tube in to the wheel well, go to my info page.
You definitely want to reroute that line, look at my frame picture!
I shoved a piece of pipe in the old hose and put a rubber hose on the other side jumping over the frame. 2 small clamps and a few zip ties keeps it in place.
utkrstam
