FJ/5100s lift fit 285/70 on stock trd wheels?
Jeremy107
Member
I bought a set of trd pro wheels for my 3rd gen, well come to find out my wife wants them instead. Can they fit without rub on this lift set up on 285/70s?
Lift is 5100s (1.75") and the FJ coils all around. Not sure of the offset but they seller told me they came off a 2018. wheel reads 17x7 stamped
Edit: When I first read this I thought you were talking about the spare tire... but I realized you are probably referring to using them on the truck.
That tire measures out to about 32.7”… It might be a bit snug but you could probably get it to fit.
I have a fully aired 32.1” tire under my truck right now and it fits pretty well, but if I put a tow receiver ball or D ring recovery loop, I often times have to drop the spare tire a little and push it forward to get it in the receiver. After I put it in, I just raise it back up.
Tires tend to vary a little based on the manufacture so sometimes its hard to tell without trying it.
Not sure if it matters or not, but all of this is on a V6 truck.
Sorry about that I will edit the post, I am referencing fitting these wheels and tires under my wife’s lifted 4th gen with the current lift set up above
You will likely experience some rub in the front. Why not bolt them on a see for sure where and how much?
More than likely what I will do, just slap them on and see what happens. Wasn't sure if anyone was running the same set up since the FJ lift is so popular. Will take some pics and post on here once I am done for others to see in case someone searches
