FJ Cruiser bilstein shocks/springs lift HELP!
The FJ front shock will NOT work, dont know about the spring. Best OEM lift for the front is the Tundra TRD springs and shocks.
okay thanks i have looked for the tundra trd front spring/shock for a while now and I cant seem to find anything. The only thing i have found is a NON TRD tundra spring/shock will that work but just not give the same amount of height?
Do you know where I could find a TRD Tundra spring/shock?
So I found this on craigslist. so my understanding is that these shocks will work for the lift but will the coil springs work for the lift as well? would it fit under my rig and how much of a lift would i be looking at getting. If so would I be able to use the top hats off of my stock front coil struts? or would I have to get new top hats?
Also is this a good deal and worth getting and putting on my rig? right now Im at stock height.
Thanks any info will really help and be much appreciated
http://www.toyota-4runner.org/3rd-g...-fj-cruiser-spring-lift-3rd-gen-4runners.html
...in addition to what others have posted
Toyota dealership will have the trd tundra springs and Sonoran Steel also sells them in their lift kits and im sure you could order just the fronts.
patnewton
