FJ Cruiser shift knob - No cutting or trimming!
Where are people buying these? Just the dealership?
At the dealership or eBay...
Current part numbers are:
33504-35093-B0 (all black)
33504-35103-B0 (black and silver)
36303-35200-B0 (xfer case knob - black)
36303-35210-B0 (xfer case knob - black and silver)
I'm resurrecting this thread as I just did this swap myself with an 8mm set screw. However, the knob turns until it's just about tight then, with about another quarter turn, it's suddenly more loose than it was. Rinse and repeat when I start to turn it again. Should I just dab it with a little blue Loctite? Wrap some plumbers tape on the lever before the knob goes on? Ideas on what my issue is? Thanks all!
Maybe you overturned and wore out the plastic threads on this inside? I actually did the same thing and ended up just replacing it. Though I did just live with it for a while. Maybe the loctite idea might work?!?
I was wondering if I wore out the threads myself. Hopefully that's not the case but we will see. I'd really like to not have to buy a second one haha
It’s been a few years but I just inserted a small 3D printed spacer inside the shifter. From what I remember, the shifter is a bit tall for the 5th gen threaded shifter rod. Don’t quote me on that, I can be wrong…
Now y'all have me thinking about doing this. It's always bothered me that there's a big knob sitting on top of a skinny post (insert juvenile sexual reference here) and looks so out of place with so much of the post showing.
