fj steelies ?
NCrunner0
I am switching to fj steelies tomorrow, can/will the tpms switch over or should i just disable it? Will the lug nuts from my aluminum wheels work? Thanks
When I put mine on I disabled the TPMS and removed the sensors from the wheels. No idea about your lugs.
The lug nuts may work but they're not designed for this style of wheel. On the FJ wheels you want a nut that doesn't have the flat surface for contact like our OEM nuts do. They'll also stick out like a sore thumb due to color. You can pick some up online for $50 or so.
No idea on the TPMS. Way back in 03 we didn't have to deal with that nonsense.
OK, thanks guys! Wonder if i can pick up the lugs at a local parts store?
CXS, did you use the write up found on this forum?
CoaterZ_FL
